My b2150 HSD developed a "chatter" when clutch was engaged. I split the tractor a couple of weeks back, once inside I found the input shaft and clutch plate splines pretty much wore off. I ordered a new shaft, throwout bearing, clutch plate (the pressure plate looked like new), pilot bushing, and seal. This weekend I started to put it back together found that there wasn't a pilot bushing in the crankshaft, the seal was still intact. The new pilot bushing (66621-14120) is way too small for the bore in the crankshaft, it just flops around in there. It doesn't appear that the crankshaft is wore badly, it seems to me that I need a different size bushing, the dealer says that is the only one specd. for my model and I'm out of luck. Anyone got any ideas or if there could be a different bushing on some of them? Thanks for any info. you can give me.
