Parts for B7200 4wd Tractor
gtvaldez
B7200D
Mar 6, 2016
9
I am looking to rebuild the transmission, replace the clutch and replace the hydraulic box for the front loader. I think this is the problem why it won't lift a load in the bucket or hold in position. Who would you recommend to buy parts from to undertake this task?
thanks
al m
Kubota b1750,60" mm,48" argo trend snowblower,5' grader blade
Jul 30, 2012
258
smiths falls on Canada
Thanks will look into that. Any place you recommend to buy a seal kit from?
If you are handy,tear down the cylinders and have a look,if not,either way,seek out a reptuple hydraulic shop in you area.
Does the bucket curl under load? Does the three point function as it should?
1,848
Go to Kubota.com and they have an illustrated parts list
Locate the parts you need (be sure to use the serial number of the tractor where needed to get the correct part number)
Then order from local dealer, Messicks for Coleman online
