Part for Bx1500
wardsfarmnj
2016 L3901 FEL 2004 BX1500 FEL 71" Tiller 37" Tiller 71" Finish Mower Flail Mow
Jul 8, 2015
49
Mannington Twp. NJ
There is a switch that is located behind the rear wheel, Where the shift linkage is, I will call it the neutral safety switch for a lack of better term that essentially lets the tractor know it’s ok to start. I think that is going on my little bx and want to replace it but do not which switch I should be buying. Thanks in advance
6,593
Go here:
https://apps.kubotausa.com/illustrated-parts/
Agree to the legal and put in BX1500 for you model number. "Open" the parts diagrams, then Electrical System, then Switch/Sensor.
The diagram I see shows 3 safety switches, along with the Part numbers. Couple of them look to be 2 each. One is labeled "Seat", the others "Safety". Hopefully you can pick the right one out from the diagram.
