Oil pan repair?
4,293
Depends on type of gasket. If rubber or cork gasket do not “spread” the gasket by overtorque. If paper or RTV just snug (300 in-lbs) should do it.
Bark
L4701/FM2560LA765/BB2560Pittsburgh disk Titan P forks
Feb 18, 2020
202
55
North CA
Yeah, better too loose than too tight. if it seeps or leaks you can always snug the bolts up a little.
How did you finally get the pan off?
whitetiger
Nov 20, 2011
3,812
2,217
Kansas City, KS
The WSM does not specify a specific torque. If they are 8mm bolts, it should be about 20-22 Ft Lbs or 250-inch lbs.
Abe
L2250, 60"MMM, 6' Rear Blade, 6' Front mount Blade, 2 Furrow Plow, 7' Lift Boom,
I guess you could call it the right tool for the right job. I picked up a sturdy putty knife with a sharp edge at my local auto parts store, gave it a couple of taps, and she came down. I was frustrated and exhausted with the wrong tool in hand the evening when I first tried. Those are the times I've learned for the most part to step back, take a breather, and get back at it a bit later.
SidecarFlip
Banned
563
Wolfman can correct me if I'm wrong but if it was me, I'd put a smear of 3 Bond on both sides of the gasket before installing the pan. Great stuff.
Bark
Feb 18, 2020
202
55
North CA
:cool:
I have never used 3 Bond. Does it scrape back off when needed like permatex blue?
Pau7220
Aug 1, 2017
786
281
Clarks Summit, PA
Depending on what was original, standard practices would be...
Gasketed.... a small amount of adhesive such as 3M weatherstrip adhesive to hold in place during assembly, or dry. Anything more will act as a lubricant and may cause gasket to squash out.
Machined surface with chemical gasket... Permatex ultra black would be ideal. Used by OEMs for maximum oil resistance.
SidecarFlip
Banned
563
:cool:
3 Bond is Kubota's preferred gasket sealer. Most all mating surfaces of your Kubota will have a film of 3 Bond on them. Far as I know of, it's a dealer item. I keep a tube hand on the time. Good stuff.
If you look in the WSM, it will call out 3 bond quite often.
Just had my back pto case off to replace a seal. 'Glued' it back on with 3 Bond.
Pau7220
Aug 1, 2017
786
281
Clarks Summit, PA
3bond is a grey silicone gasket maker... equal to ultra grey.
Kinda like a Rotella vs Delo war.
Ultra black still has the highest oil resistance.
Maybe there wouldn't be so many questions on HST suction screens filled with grey crap if black was used.
