I have an L245 2wd over the past two years have rebulit everything paint and all. its in awsome shape. I love this little tracctor. Never had an engine issue. Was bush hogging thick stuff the other day and noticed it spit water out the overflow. It had never done that. Stopped with engine stll running began to hear a squeak squeak squeak noise from the front end of the motor, so I shut it down immediately. waited and it got hotter and started whistling. I let it cool down and opened the radiator to check the water. it was fine. Also checked the oil, it was fine . Tried to crank again after cooling down and it turned about half rotation and stopped. It would not turn over. I Stuck a screw driver in the port and tried to rotate the motor flywheel and it would not move but maybe a 1/4 inch back and forth.
I checked the clutch for free wheel. it was fine, I pulled the hydro pump still stuck. So. I pulled the tractor apart put a pipe wrench on the front of the splined shaft and tried to turn it. Wouldnt turn. I thought I may have blown a head gasket and have water on the top of the piston. so I pulled the head and no water on the pistons. head in good shape not warped or blown head gasket. It still would not turn over manually with a wrench. Finally i rocked it back and forth fairly forcfully and heard it pop free and now it turns just like it is supposed to. All the pistons moving, no crazy grinding noises. smooth. None of the cyclynders are gauld or worn. no water in the oil, dropped the pan to check for metal or berring debris...nothing. Now dont know what to do or where to begin.
Do I buy a head gasket fill it with oil, slam it back together and crank it? or do I tear it down and sell parts on line to recoupe my money? do i pay $1000 for a rebuild kit and pay someone (dont know who to trust) to rebuild the motor for another 2 grand. Dont know if these tractors are worth that much money in value.
Thoughts? Suggestions would be welcome.
PS. does anyone know where to get the cheapest head gaskets or an engine rebuild kit is?
Thanks
Po-man out!
Thanks
Po-man out!
