Newbie
69 SS
2015 L3901 HST,with Canopy,LA 525 FEL with SSQA bucket
Sep 26, 2015
106
22
Ft. Inn sc
Traded in 83 Ford 1710 FWD w Bushhog L4220 FEL ,2689 hrs .for 2015 L 3901 HST 4WD with top, LA 525 FEL with SSQA bucket .have put set of Kens bolt on hooks. Took 5 ft wide tooth bar off of Bushhog loader bucket,cut in 2 places,added 6 in piece ,welded back together and now my new Kubota has teeth! So far have 25.7 hrs on tractor,did first Regen at 21.3 hours,had to run it at 2500 RPM for .5 hours to get flashing light to go off. Have Hardee 5 ft bushog,John Deere set of 8 disk turning plows that pop bought new in 57!, Land Pride 6ft scrape blade, Leinbach rock rake,traded in Dearborn scrape blade, Dearborn Cordwood Saw for these,pop also bought these new in early 60s. Looking to train grandkids to run Eqipment . New to forum and just sharing story. Good luck to all on your projects.
4,534
First off Welcome to the Orange, it sounds like you got her pretty well figured out,, good on you :D
NOW is it a 396, 427 or 454 :confused:
69 SS
Sep 26, 2015
106
22
Ft. Inn sc
Camaro,SS 350,Auto,gauges ,tilt,factory a/c,blue with black vinyl top, monumental act of stupidity,painted it white in the 80s,retirement project,bought it in 78,needs lots of TLC,and $$$ . Wish it was a factory big block!
