Need radiator fan blade
Weld73
1979 b7100, 2 Bassett hounds
Jul 12, 2022
McHenry il
Hi orange tractor talks, I have a 1979 b7100, #3 son didn’t lower the loaded bucket of moving tractor while helping demo a deck. A 4x4 post came out and smashed radiator. The radiator is in repair shop. I seen some wear marks from the fan blade and radiator repair man suggested a new fan. Anyone know where I can find one? It’s four blades, 10 3/16” diameter.1 1/2” deep and goes on a 7/8” shaft. Any info on parts for this old work horse will be greatly appreciated. Thanks
2,025
Your dealer can probably get it for you.
You can also go to Kubota dot com and illustrated parts list and agree to terms then search for your tractor model number and search through for the engine section and then the fan and associated hardware and lock plates
Be sure you see if the parts have alternates for serial number breaks. So know the serial number of your tractor.
You can probably order online from Messicks or Coleman or see what you find on the web by searching for the part numbers you have.
Weld73
Jul 12, 2022
McHenry il
This should be it.
Thanks pau messicks confirmed it’ll fit. It’s on the way.
Thank you Russel, I confirmed with messicks this morning it will fit and it’s on order. I appreciate the knowledge. I’m sure I’ll have more questions later
