I got the rototiller all hooked up, but the splines don’t want to match up, and I don’t know how to freewheel the PTO so I can move it to the correct position. If anyone can help, that would be great.
Yes, I am pulling back on the collar.Just to make sure, are you pulling back on the lock collar while trying to fit the pto to the tractor?
Will try that thanksThere are tools to turn the tractor PTO shaft like this
PTO Align™ Spanner Wrench - PTO Link
The PTO Align™ spanner wrench is designed to assist the alignment and rotation of most PTO implement shafts to tractors when connecting the driveline using the PTO Link® System. Because some tractors do not “freewheel” at the tractor’s PTO, in these cases, the alignment tool helps to leverage...tractorptolink.com
You may be able to pick the tiller off the ground and rotate the driven shaft but that is dangerous unless you put some blocks under the sides and set the tiller down on those.
That confirms the collar isn't seized up. Other than the suggestions above, I would start the pto momentarily and shut it off and with the tractor turned off try again and see if it is aligned better for you. Ensure nothing is close to the tractor pto shaft of course. Good luck.Yes, I am pulling back on the collar.
A lot, maybe all, of the newer tractors have a brake on the PTO shaft that engages when the PTO is in neutral. This makes hooking up the shaft a pain, as you've discovered. As someone mentioned, often it's easier to lift the implement and turn it.I got the rototiller all hooked up, but the splines don’t want to match up, and I don’t know how to freewheel the PTO so I can move it to the correct position. If anyone can help, that would be great.
I am SO GLAD that I bought a 2501 while they were still available before they mucked it up with the 2502!I have not found a way to be able to spin the pto shaft on my L2502, the L3902 uses the same pto system as the L2502.
