My new b2601
MXBX
153
Maryland
Here she is under construction. Neil Messick sent me this yesterday. Just a few more days. My BX2360 gets picked up tomorrow. Sad to see her go but super psyched at the new possibilities.
[/IMG]
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,455
469
I can still see it? Don't know if I'd like them scratching my grill guard by using it to the lift the tractor like that though. My dealer takes a little more care.
MXBX
153
Maryland
I agree and have written to them to make sure everything is touched up. Bottom line, however, is that I'll be using this tractor and it will be getting scratched up some. I just want to make sure I'm the one doing the scratching.
MXBX
153
Maryland
Picture Porn
Arrival
3rd function controls on joystick
Valve
Oversize Bucket and Loader
Everything Checked out nicely. About to take her out to mow the fields.
TripleR
Sep 16, 2011
1,911
SE Missouri
Congratulations on your new tractor, it is a real improvement over its previous model.
MXBX
153
Maryland
can you check your 3 pt hitch for me. Mine does not start raising until position 4. Is yours working properly?
One of the first things I did. Just finishing all the reading and wanted to gather as much info as possible before I commented, but....Mine works just like yours. Furthermore I'm not noticing any difference between positions 1, 2 and 3.
At this point the only thing I've hooked up to the 3ph is my carryall/ballast. I have used the mower for about two hours and I find all adjustments there are working as expected.
Sorry, not much help, I guess. Maybe raising and lowering the 3ph in the present configuration makes no distinction between positions 1, 2, and 3. I'm still trying to figure this out.
hurleyhuckster
24
Kingston, NY
Ok thanks for the feedback. Good to know mine is not messed up. I didn't think it was a big deal.
I am noticing a pretty good whine from HST when under load like going up hill and scraping with loader. I guess thats pretty common, but would love to hear what yours is like when you get a chance to give it a good runnin'.
Also, my FEL bucket is a little crooked, also not uncommon from what I gather. So I guess I need to find a level spot and loosen the bolts and put a little down pressure on her an re tighten. Rear tire pressure is fine. How does your loader look relative to tractor?
I been digging up a storm with her, dealing with bamboo that has overtaken the property, but we got er licked!
I haven't really run her full bore yet due to break in, been going like 75% max.
Greased her twice now probably going on 20hrs. Getting a little creak in the boom swing, been trying to get some grease in there but still a squeak now and then.
The only reason I am in here on the puter is cuz it got dark out!
Fiziksgeek
Massey Ferguson GC2400
Apr 8, 2015
20
Oxford, CT
MXBX--What tires did you go with on the 2601? Looks like they offer 2 turf options:
Wider
front 22x8.5x-12
rear 31x15.5-5-15
or Taller
front 23x8.5-12
rear 33x12.5-5-15
Fiziksgeek
Apr 8, 2015
20
Oxford, CT
I went with the following:
front 23x8.5-12
rear 33x12.5-5-15
Any particular reason? I think that would be the better choice overall. You get a little more ground clearance, and perhaps less scrubbing on turns that with the wider rear tires...? But maybe a little less stable if hills are a concern..?
MXBX
153
Maryland
The truth is that that I told them I wanted turf tires and that's what they put on. I will say the tractor seems very stable on hills but I usually go up and down or when running across a slope, take it slow and easy. The extra ground clearance is always good.
Fiziksgeek
Apr 8, 2015
20
Oxford, CT
That's fair. I wouldn't know which to choose if I had to decide....
MXBX
153
Maryland
I wanted to post something here that I also posted on TBN re: my new B2601 for general discussion.
Hopefully this will give those considering the B2601 an idea of the quality of the cut. It is longer than my old BX thus less nimble around obstructions but on the straight paths it is a dream. I obsessed about R4s vs Turf and am really happy I went with the Turf tires. This year has been ridiculously wet and the R4's would have torn up the yard and fields. I've been mowing every 5-6 days to keep up with the growth. There is definitely a clench factor on steep slopes even in 4WD. I'm considering wheel spacers.
I installed LED lights and a waterproof switch. You will find a pair of connectors under the right rear fender. Can't miss them.
The Tool Box that came with the tractor was too small for my needs so I bought this waterproof 50 Cal ammo box off Amazon for about $30. I drilled holes in the bottom and used the mounting system kubota provided.
I found this arrangement for the stabilizers more convenient and way faster, simple 5 minute job once I got the parts at my local Ace hardware.
I really love the machine but have one serious gripe with Kubota re: the on and off of the FEL arms. It seems to me that the tractor has to be PERFECTLY level to have a chance of a good marriage of parts and even then good luck. I hate the design of the FEL stand. You'd think they could add more surface area to the legs so you could remove the FEL on grass or dirt. It is a friggin tractor. I really liked the Deere set up much better but in spite of this issue preferred the Kubota. I do remove the FEL regularly, maybe I'm doing something wrong and one of you pros can help me out here.
Almost forgot this is a great add-on.
atljetmech
B2601 w/ MMM & FEL
Jun 24, 2015
36
Ball Ground, GA
Very nice and I like the stabilizer link lanyards!
I have yet to remove my FEL but thanks for the heads up. Maybe a foot mod or extra hole positions will be needed to make more user friendly??? :confused:
I just picked up two small plastic ammo cans from Walmart at $7/each to mount in place of the pathetic little box Kubota provided!
bcuster
B2650 w/ cab, FEL, BH, 63" snowblower w/ extensions, grapple, forks, box blade
Jul 10, 2015
State College, PA
MXBX, is that the EA 54" single lid root grapple? That's what I'm strongly considering for my soon to have B2650. Can you post more pics of the grapple and connectors? Are they male and female 3/8" NPT hydraulic connectors?
