My DIY Cab
555
46
88
Ontario
Well just putting the finishing touch's on my DIY cab before winter, took me 2 months off and on (more on) to build. Took ideas from YouTube videos and made my own plans. Did not like any of the after market cabs for my B2601. This one will stand the test of time. Made from 2" tube frame and 1" tube doors with flat bar on outside. Ran all my wiring through the tube with extra pull wires. The cab is all glass except lower doors which is lexan. Primed painted and clear coated.
Reactions: 13 users
ve9aa
Apr 11, 2021
1,193
972
NB, Canada
Looks pretty rugged.
Any plans for additional lighting, heating, stereo? :unsure:
3,289
Very nice! Looks like great workmanship!
3,296
I remember following a long detailed thread about a cab built that seeing your build reminds me a lot of.
Any chance that was your thread? I can't remember if the thread I am thinking of was posted here or on TBN. If it was here, not you then, since you are a new member...
555
46
88
Ontario
Very well done. What material did you use for the lower back wall ?
Well I thought long and hard about my roof material, not using wood probably have to go to sheet metal but did not like the idea off the paint lasting. Then one day I saw an add for a free truck box liner I thought that's it so I went and got it and cut the bottom of the liner for the roof and used another flat section for behind the seat and down around the hydraulics. Nice thing about the liner what ever material it is made off it will melt together easy so I finished the front and back off the roof with liner pieces, 45'vd the corners and melted the cuts back together to hold worked good.
555
46
88
Ontario
No that was not me
5,185
Superb job !!!!
555
46
88
Ontario
It certainly is a professional result!
To the OP, are you planning to put the top half of the ROPS back on? Just curious, nothing more…I guess it may block your view a little.
Hi, No I wasn't, first Can't get in my shop when its up, can't see when snow blowing that good, and I'm on level ground so pretty safe and I think with the way I built the cab its just as safe or safer thks
Ping
BX2370-1
Dec 25, 2018
341
309
Troy, Ohio
Outstanding job on your cab! You can be proud your workmanship and glad you've included a heater this winter.
Regards,
Jchonline
599
Red Feather Lakes, CO
Looks very well designed and built. I always worry about tipping in these lighter machines. Please be careful.
555
46
88
Ontario
Thankyou, I think I will in the near future put wheel spacers on, but very expense here in Ontario
NoJacketRequired
May 25, 2016
431
71
Ottawa, Ontario
Nice looking cab. If you have heat in the cab you may want to make at least one of your windows and "awning-style" opening window - that is, hinged at the top so the bottom pushes out and away from the cab frame. This will allow for ventilation (especially when snowblowing and your coat might be covered in snow that melts, increasing the humidity level in the cab rapidly, resulting in you being "fogged in").
Also - I have one cab that limits my view of the 3pth lift arms and drawbar, much as yours does. It's not often I have to look down there but when I do, it's frustrating not to be able to see what I need to see. In the photo below you can see how the lower portion of the rear wall of the cab is glass - this is truly helpful in some instances. With this in mind you might give consideration to replacing that lower portion of yours with lexan or similar material. Just a suggestion. Anybody who takes on a cab build is a brave soul and you've done well with yours!
