While cutting hay last night a loud noise and one of the two hydraulic lift arms dropped. Noticed a failure in the connection to the lift shaft. Pulled of the drum mower and pulled off the arm this morning. Ordered a new one but noticed on the removed piece several cracks in other areas. Wondering if anyone else has experience? I fear I'll need to order another for th other side.
The drum mower is unbalanced as installed by design and puts more weight on the arm that broke. Curious if there shouldn't be a 'better' weak point in the linkage? The ground is bumpy and it
The two arms are identical and I'm contemplating swapping sides after inspecting for cracks in case it was a poorly made or improperly stressed relieved. Any advice.
