Mx5100 key switch replacement
FlanneryFarm
Kubota MX5100
Jan 6, 2024
Oldtown, KY
The key switch on my Kubota MX5100 is sticky meaning that it sometimes shuts off after starting you keep fiddling with the switch and it will stay running. I am wanting to clean or replace but do not know how to take switch out of dash. Im afraid of breaking it so any help appreciated
Brian Flannery
1,847
Looks fairly straightforward
go to this website https://apps.kubotausa.com/illustrated-parts/
It looks like there is some removable cover that is part of the dash. You may have to get the steering wheel off but I don’t know that for sure.
It looks like the key switch is the style that has a silver round nut holding it into the dash. There is a slot in the dash for a tab to keep the switch from rotating and a washer underneath the nut to allow it to get tight.
If you are replacing it buy the switch assembly and you will see exactly how it works.
Have you tried cleaning the existing switch? I would say that you can use WD40 or something better and see how it works after spraying down the key slot.
jyoutz
Jan 14, 2019
3,348
2,391
Edgewood, New Mexico
Use powdered graphite for locks and key slot assemblies, not WD-40. That’s what a locksmith told me.
