MX5100 HST 4 Wheel Drive Linkage
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
546
310
Mandeville Louisiana
When going from 2WD to 4WD the linkage snaps in fine and performs correctly, however when returning back to 2WD at a stand still and with some movement, it sometimes is very diffcult and needs to be forced more then I believe is necessary. Any thoughts? Thanks
RBsingl
Kubota F 2690 72" rear discharge deck, Deere 955
Jul 1, 2022
485
562
Central IL
Disengaging the front axle is easiest while moving and gradually starting to slow so that the driveline isn't under load. For the same reason, it is preferable to disengage while traveling in a fairly straight line.
My Deere 955 has always been the same way and Deere advises that although it can be shifted in and out of FWA (Deere refers to it as front wheel assist instead of 4WD on their smaller tractors with unequal tire sizes front to rear) under speed and load, that shifting out of front wheel assist will be easier when the tractor is moving without heavy load on the driveline.
Rodger
Hunter1157
MX 6000 HST Cab, Kubota RTV X1140
Apr 26, 2020
32
21
Palestine, Tx.
On my MX6000 I found mine goes from 4WD back to 2WD very easy if I just touch the HST pedal in reverse while pulling the handle. Of course this is from a stand still.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
868
canada
Same as my L6060. If it seems tight, I back up a bit and it pops right out. My RTV is the same way also.
4,877
If the loader is on, raise the front off the ground with the loader. That relieves any pressure on the gears in the driveline and makes shifting in and out of 4WD quite easy.
troverman
Jun 9, 2015
1,178
264
NH
Also, turning the steering wheel all the way to the right or left while stopped will allow you to make the shift back into 2WD easily. It is annoying how these tractors will drop into 4x4 easily, but be so difficult to smoothly get back into 2wd. I guess you can have peace of mind knowing they are all like that.
