I purchased a ZD21 with a 60" deck at an equipment auction. Coming from an auction I don't know anything about it's history. My problem is; the mower blades turn backwards (CCW). The discharge chute is on the right side of the deck, but looking down at the deck, the blades are turning CCW. So, it looks like someone swapped decks (or gearboxes) and didn't know (or care). Looking into the gearbox I have surmised that if I can swap the top bevel gear to the other side it will reverse the outgoing direction, and my problem is solved (it looks like this is possible). The problem being, the pinion shaft needs a spline on the opposite side. So, I look in the manual, and low and behold the pinion shaft has two part numbers, but no explanation as to what they are. Are the two pinion shaft numbers to allow a chanfge of direction? If so, which shaft do I have, and which do I need? Has anyone heard of this before?
