Mid mount mower deck RCK60-30BA manual
Dae06
2019 Kubota B2650 Cab.
May 10, 2018
173
11
Minnesota
I cannot find the manual on-line for the above mentioned mower deck. I can find the: RCK60-30B, but am unsure of the difference between the 2 models. Does anyone have an electronic copy of the manual?
Also, for the same mower, what pin (size, length and type) do you use for pinning up the deck when wanting to use a rear 3-point hitch attachment without lowering the mower?
Thanks
Dae06
May 10, 2018
173
11
Minnesota
You have listed RCK60-30BA in title and you say you have it's manual, which model are you looking for?
Have you tried here for what you are looking for?
https://apps.kubotausa.com/illustrated-parts/
Sorry, my bad. I have edited my post to describe the two different model numbers correctly.
When I do a search for this model number in your link I get "No Information Found"
Dae06
May 10, 2018
173
11
Minnesota
Ok, I've learned a little bit in the last hour.
1). 100 td: If I do a search for RCK60-30B I get results (RCK60-30B(A))
2). From Kubota: Check out attachment below. Most important for Turf tire owners.
SDT
Apr 15, 2018
3,706
1,425
Your dealer should be able to help you if you cannot find it online.
If they don't, you need another dealer.
SDT
  • Dislike
