Maintenance Inquiry: Excessive Resistance in Driver's Side Window Regulator - Kubota RTV 1100C
Joel P
Kubota RTV 1100
Nov 29, 2025
Shelbt MT
Hi All :driver's side window exhibits a significant amount of resistance when being rolled up. The effort required is substantially greater than for the passenger side window.
I would appreciate any recommendations regarding the standard maintenance procedure for this system. Specifically, I am inquiring if there are any specific internal points or guide channels that should be lubricated, or if there is an adjustment procedure for the window regulator or sash that should be performed to correct this stiff operation.
Thank you for your time and professional assistance.
Mark_BX25D
Bx25D
Jul 19, 2020
1,911
1,384
Welcome!
I don't know your particular vehicle, but I think you'll find there's a panel that can be pulled off, and the guts of the mechanism will be pretty obvious. Window mechanisms are pretty simple and pretty much common. There's likely a track that can get gunked up, and the lube points should be evident.
It looks like there is an exterior door panel that is held in by a rubber gasket. Maybe someone who has done this on your vehicle can chime in.
