JoshHughes
M95S 4wd cab with FEL. L3200 with FEL & backhoe. Plus lots of other goodies too
Ok, so I have a 2006 m95s 4wd cab. Bought used last fall.
The radio hasn't been 'right' since I've had it but it has gotten worse with this hay season so I finally broke down and bought a new head unit and speakers (have head unit in hand, speakers are being shipped).
So, I get home, insert the removal tools into the factory unit and slip it out of the way and start examining wires to see where to begin the wiring fun.... I have found that the 12v source wire has no power at the main plug. I found the wires in the floorboard and checked it... Has power, checked again up top.... Nothing..... Aaaaahhhhhh!!!!!!!!
I can jump the switched 12v to the constant and the factory unit will kick on, so I know that is my problem. Bt I don't know how to gain more access to the area to steal power from my ac.
While having it jumped, I found that my speakers main problem is that the plug is CRAP, all the speaker wires are loose causing intermittent shorting. I will possibly cut the plug out and replace it or just solder my own plug on there, even though I hate the idea of cutting the factory harness (it's a thing I have from working on vehicles.... I hate it when people cut factory wiring harnesses because it makes for rats nests and impossible to trace wiring later).
Any help on this issue word be great.
Thanks.
Sent using Tapatalk, via an iPad, meaning, if there are stupid words blame autocorrect and if things are stupidly punctuated blame the iPad keyboard.
Thanks.
