M9540 Shifting
tthorkil
M9540HDC12 / LX2610HSDC / ZD1011-48 / Bobcat S250
Jan 1, 2011
323
87
Bagley, MN, United States
I recently purchased a 2007 M9540 and have noticed that the gear shifting 1-6 (range H - L works well) seems to be rather loose and sloppy. Sometimes I have released the clutch and only heard gears spinning - no movement. Is the shifting on this tractor normally rather loose and if not is there a way to make the shifting a little more 'crisp'?
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
17
Northern California
There are all sorts of linkages and actuators for shifting these tractors. That's all I know about it.
I have read posts that discuss how to adjust them but do a search of this site and others to see if you can come up with something more specific.
A Kubota dealer may know more since there are TSBs about the issue if my memory is correct.
E/S
2009 M8540HDC 4x4 w/ Cab
Jan 6, 2010
251
Reno, NV
If it does it in all gears, check the shift lever where it bolts to the linkage in the cab.
E/S
steve l
2 m9000,9540 all cabgmd700 kuhn 605m vermeer,r23a vermeer rake,468 jd baler,
Dec 29, 2010
77
bullard,texas 75757
i have 9540 that i bought new in 5/08 and i have noticed that i cant shift from low range to high range with the gear selector in first gear.dont know if it is a safety feature or what.the tractor has 1800hrs on it and has done since day one.
tthorkil
Jan 1, 2011
323
87
E/S
It does it in all six gears. Any tips on what I need to disassemble to get to the linkage in the cab?
headhunter
M9540
May 31, 2012
West Tennessee
I had the same problem with my 4 speed, very sloppy in one direction and didn't want to go into 3 or 4 & my father had that problem with his 6 speed.
If You take the whole console apart to get to the primary linkage in the cab, you will find a small 8mm nut that is very loose in a universal type joint. tighten that back up and should be good to go, I'm not sure if the cabbed models are exactly like ours, but we just had to remove all the rubber boots, unbolt the loader controls, then take the plastic cowling off and keep searching and removing and it'll appear.
good luck. Hope that helps some.
tthorkil
Jan 1, 2011
323
87
headhunter: I had the same problem with my 4 speed, very sloppy in one direction and didn't want to go into 3 or 4 & my father had that problem with his 6 speed.
Thanks for the information. I do not have much time to work on the tractor and I live about 240 miles from my farm. I do not have any heated facility to work in so I will be waiting until warmer weather arrives to look at this when time permits - I also have to look into why the intake manifold air pre-heater is not functioning. I have the electrical diagrams - just need the time to disassemble the dash and get to the ignition and relays that control the power to the heater coil.
I will post back when I have looked into this and discovered the cause - I hope that it is a simple fix!:)
tthorkil
Jan 1, 2011
323
87
pmhowe: ..and he didn't even tell us! Nonetheless, Headhunter, you provided some useful information. Thankyou.
I guess that I should have been a little more clear about whether I had found any resolution - I have not. Since the tractor is operating satisfactorily and I have not had any spare time that I have spent trying to resolve the shifting 'annoyance' - I have just been waiting/searching for information to help make the 'fix' as easy as possible. Thanks again and please add any more info/hints that might make the resolution as simple as possible - I like 'quick and easy'.:)
pmhowe
L4240, Ford 8N, Kioti CK 2610
Jun 23, 2012
117
Banner Elk NC
Hi TThorkill,
You and I posted at the same time. I didn't mean to imply you were not clear in your response. I was responding to GWD's post and commenting on the fact that the original poster never got back with his solution. Anyway, good luck solving your problem.
PMH
steve l
Dec 29, 2010
77
bullard,texas 75757
i have a 9540 that i purchased new in 5/8 it has 2700hrs it also does the same thing
