Any thoughts on the source of fuel in the engine oil? I replaced the lift pump assuming it was a leaking diaphram without fixing the issue. It will add about a gallon of fuel in 15/20 hours of run time. Tractor has about 1750 hours of operation.
Performance is good. There is no excessive crank time if it has been setting for a few days with the fuel shut off. The suggestion on the pump seal is probably the answer. Thanks.
