M8580 charge system troubles
mb1995
Vanderhoof, B.C. Canada
Have a M8580. When started, lights indicate "alarm against electrical charge system troubles". Took alternator to test, no problems with it. Any other suggestions as to where to look from here?
whitetiger
Nov 20, 2011
3,186
1,604
Kansas City, KS
Clean both positive and negative cable ends at battery, clean ground cable end where it bolts to tractor and positive cable end at starter. A good share of the time it is where ground cable is bolted to the tractor frame.
Also check the fan belt tension.
E/S
2009 M8540HDC 4x4 w/ Cab
Jan 6, 2010
251
Reno, NV
Pull the alternator and have it checked. Could be a bad diode or a loose belt.
E/S
