M7580 wet brake repair advice needed.
Thejeep2167
M7580
Sep 13, 2022
Tn
Hello first post here.
I have a kubota m7580 that I purchased used. When I got it the left brake pedal required pumping to lock up the left rear tire. I bled the brakes with traveler tractor fluid, and got A lovely yellow snotty mess out of it upon bleeding. I adjusted the pedal position and both brake pedals were firm and would lock up their respective tires.
On a cold day last winter the left rear tire would not turn at startup And skidded with out the brake pedal being depressed. I tried forward and reverse and eventually the tire freed up, but now the brake pedal will not actuate the brake. If I press on the pedal it is firm, but does not lock up the tire.
I switched the brake lines and the left rear brake still doesn’t work when using the right pedal either. Ie the right and left masters both work, but theproblem is in the left brake.
So my question is how to proceed here. What parts need replacement. Do you think it’s just the seals or the seals and disks/metals. What are the chances that I warped/bent the shaft they slide on?
Thanks
Pau7220
Aug 1, 2017
785
279
Scranton, PA
I hate the sound of that statement.
What exactly does it say on the master cylinder cap or in the owners manual to use for brake fluid? I looked, I can’t find it.
If you see DOT3 or DOT4, plan on rebuilding everything.
whitetiger
Nov 20, 2011
3,249
1,675
Kansas City, KS
They use UDT, SUDT or ISO 32.
Thejeep2167
M7580
Sep 13, 2022
Tn
so it lookslike at the least I need 10,20,40,50
do 30(piston) 60&70(disks&metals) ever go bad?
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,254
161
Coyote Flats,Texas
It wouldn't surprise me if you didn't need to replace brake disk(item 060) & possibly plates(item 070).
