M7060HDC cab air issues
ARM7060
M7060HDC
Jan 10, 2023
Ruston, LA
I've got a M7060 and the cab air/heat had been working. Now, everything comes on like it should, but air will not blow with either heat or a/c selected. I've checked all the fuses and they are all good. Not sure what else to look for.
Dustyx2
BX22, M7060, Landpride RC-2512, Woodmax SB84
Feb 19, 2021
224
66
NE Wyoming
There is a fan relay behind the panel under the seat. Control side of the relay is a 5 amp fuse and the fan power is a 20 amp but you said you have checked them. There are also slow blow fuses at the battery you might check. You could swap relays to see if that is the problem.
ARM7060
M7060HDC
Jan 10, 2023
Ruston, LA
Are you saying there is a relay under the seat?
Dustyx2
Feb 19, 2021
224
66
NE Wyoming
Actually there are 2 relays. A "Blower Relay" and a "Blower High Relay". Sitting in the seat, the panel you need to take off is right behind your heels.
Dustyx2
Feb 19, 2021
224
66
NE Wyoming
Ok, thanks. I will try that.
Page 109 in the operators manual shows a drawing of it in the lower right hand corner of the page. It also looks like there are two fuses in there too but I don't know what they for.
Dustyx2
Feb 19, 2021
224
66
NE Wyoming
They are for the rear and side window defogger so not the blower.
ARM7060
M7060HDC
Jan 10, 2023
Ruston, LA
Got the air blowing again by replacing this relay. Thanks for the info, I never knew they were behind that panel. Still trying to track down the working light issue.
