I purchased a used M7060HDC12 about 18 months ago with 1100 hours. I have noticed an intermittent vibration in the rear end, and if pressed, would say it is on the right side. This occurs at all speeds, and feels like I am going over highway rumble strips. It occurs as the wheels (ag tires) rotate. Vibration interval seems consistent - more frequent at higher speeds, and less so at lower speeds. It has not gotten worse or better. The rear wheels have wheel weights - not filled with fluid. I keep around 15lbs pressure in the tires. I have pulled the hydraulic filters and there are no signs of metal in the oil or filter. An independent mechanic looked at it and is baffled. Local dealer won't service it as I did not buy it from them. Is this a tire issue? I think the tires are the orignal OEM, and the tread is even with little wear on them. Wheel lug nuts all snug. Any ideas? Thank you!
