M7060 - creep gears?
mbu
260
United States
I noticed that creep gears are a "Dealer Option". So... does that mean one can purchase whatever is needed and put it on themselves?
TripleR
Sep 16, 2011
1,911
SE Missouri
Thay can not be used for heavy pulling.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,257
1,046
Williamstown Ontario Canada
These gears are intended only for farming operations requiring a very low speed but no load. Planting potatoes may be an example.
If you use a super low gear to dig your loader into a pile of dirt it will be a very expensive lesson!!!
From my manual:Creep Speed (if equipped)
Shift the range gear shift lever to to obtain low speeds.
This shifting requires clutch operation.
C Creep speed should be used only when doing one of the following jobs:
1. Deep rotary-tilling and harrowing
2. Planting
3. Turf application
Creep speed can not be used for any of the followings:
1. Pulling a trailer
2. Front-loader operation
3. Front-blade operation
4. Earth-moving
5. Entering and leaving a field
6. loading and unloading from a truck
Dave M7040
