M7040 Hydraulic Top Link
Captain13
Feb 27, 2019
521
170
Kathleen, GA
Looking at going to a hydraulic top link on the M7040. Problem is, the M7040 link is a Cat 1/2. I’m thinking of going to a knuckle end on the tractor side and just buying a Cat 2 link and using an adapter to go up from the 3/4 to 1 Inch knuckle hole.
Any issues with using a knuckle end? Fit-Rite has a 32 week lead time right now and I need to go ahead and find a good alternative. I would like to have the beefier Cat 2 cylinder for box blade work. If I go with a Cat 1, I would at least want a beefier cycling to avoid overpowering it when backing up.
Captain13
Feb 27, 2019
521
170
Kathleen, GA
MtnViewRanch, Are you talking about grinding the width of the base end or the outside edge. I already use the bushings for my Cat 1 implements so that’s no problem.
Also my OEM top link can flip and use either end on the tractor. I just have to use a bushing on the tractor end to go from 3/4 to 1 inch. I ground a bushing today so that it would fit inside the tractor mount to check to see if I could use a Cat 2 end in there with no interference.
Thanks for the help. The top link you sent looks like a beefy unit.
Captain13
Feb 27, 2019
521
170
Kathleen, GA
Ok. Didn’t know it was that wide on the hydraulic link. Thanks, again for the help.
Captain13
Feb 27, 2019
521
170
Kathleen, GA
Thanks. My OEM slides in with room to spare. I like the top link you sent. The OEM has a 10” travel where the hydraulic one has an 8-1/4. I can’t think of anything I’m hooking up that will be an issue with 8“. Only a couple of times with a cultivator have I had to get out all the way because of how it tend to tilt back when off the tractor.
