M6800 water in hydraulic oil again. Won't move at 26F. Additives?
Gus1957
M6800, L2501 TLB, BX2370
Dec 17, 2023
44
35
Cobleskill NY
Hello,
This happened to me 2 years ago at 18F. When it warms up tractor works good. Yesterday it took to 36F to be able to steer and move again.
Can anyone recommend a hydraulic oil additive to help prevent water issues?
Thank you
JasonW
562
330
Al
Additive won’t help if it’s getting so much water in it that it will not move.
How did you remedy this last time?
Is it stored outside? Open vent tube catching rain water?
Is the fluid milky?
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,272
174
Coyote Flats,Texas
Check to be sure trans case breather hole isn't clogged.
I've read where trans oil can be drained into a container then very carefully heated to get moisture in oil to evaporate, then reinstall oil.
I realize draining oil in sub freezing temp isn't a very good option!!:(
5,742
Hello,
Thank you
Sounds like a freeze up problem - ice forming and blocking the hydraulic system. SUDT2 is very good at dealing with water intrusion but no oil can handle excessive amounts.
Gus1957
Dec 17, 2023
44
35
Cobleskill NY
This am it was colder at 22F and no problems. Moved logs for 2 hours on frozen ground. Unfortunately tractor sits outside and has 1375 hours on it.
Little back breather hose is on top of fill cap on rear of transmission.
Once it got running yesterday I had to work it and glad it ran today.
I'll have to drop the oil soon and check it.
There are 4 drain plugs for the system.
