A few months ago I bought a M6060 that was in a flood during Ida. All fluids were drained and refilled and no water got into the fuel system. I've cleaned and dried out all the connectors and tested all the relays and fuses. I was able to get it to crank over and fire on a quick sniff of ether. I found that the electric pump wasn't working and the CRS harness was not getting power. I was able to trace the problem back to the ECU where I discovered it was filled with water and had two burnt pins inside. I found a place that rebuilds ECU's and sent it out where they cleaned, repaired and tested it. I just got it back and plugged everything in and now have power to the CRS system and electric fuel pump, but it still just cranks and will not fire.
I had a buddy come over who has a Kubota diagnostic laptop and he was unable to get it to establish a connection. I did test at the diag plug and had 12v and ground. I also have the 5 volt reference at all of the sensors (crankshaft camshaft, etc.)
Nothing on the guage cluster works, when you turn the key on only the screen lights up but it does not display anything.
My questions are:
Can the faulty guage cluster be part of the issue why the laptop cannot establish communications with the ECU as two can wires go to it?
I've also read about there being two ECUs one an Engine Control Unit and the other an Electronic Control Unit (see pic attatched). I assume the Engine Control Unit is the one on top of the radiator, If so then where is the Electronic Control Unit (#030)?
Is there anything else I should be checking for?
Any help would be greatly appreciated! Thank you!
My questions are:
