M6040 Gear Selector
wyrmat1
M6040 F2500
Aug 13, 2021
UK
Having problems getting gear selector into 3/4/5th gear, selector goes between 1 and 2nd ok but then will not move over to neutral and 3/4/5th, any ideas or am i selecting wrongly.
3,719
Sounds like a broken or disconnected shift-fork.
wyrmat1
M6040 F2500
Aug 13, 2021
UK
The shifting is done with cables and external linkages depending upon model.
See attached pages.
Not likely internal transmission stuff.
Dave
Hello, its the cabin model, i have just gave it a good dousing of WD40 its difficult to see below the area where the gear select is
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,275
177
Coyote Flats,Texas
Concerning my M7040 if Hi-lo shift linkage isn't frequently lubricated it is very difficult to shift between ranges'.
wyrmat1
M6040 F2500
Aug 13, 2021
UK
Range shift is fine, i an struggling trying to locate linkage for main gears, i have the front plastic off but the selector shaft goes below the floor, any pictures on where to check or lubricate would help
wyrmat1
M6040 F2500
Aug 13, 2021
UK
This is not going to be a lubrication problem, it’s going to be a fork/shifter problem which will be addressed with a WSM.
I have got a manual but i am not sure where it gives info on fork shifter location or access
3,719
Look into the section on “Travelling System”. I posted a pic above which refers to the same system on my M4700. The shifter fork will be directly actuated by your gear-shift-selector lever. See item 3 in the second pic.
