M5101N Error 21
Haspr
M5101N
Mar 17, 2023
Greece
Hi,
I am new in tractors and I have an orchard tractor M5101N (used 2200hrs).
Error 21 popped up and the manual says “Range gear shift (Hi) switch trouble”.
It happens only when I put the 6th gear for travelling home. I switch off the tractor and the error disappears. Until I put the 6th gear!
All day at work… no errors. Only when I travel! Also I don’t feel or hear anything wrong when the error appears. The tractor moves normally. I stop, switch ignition off, switch on, put 5th gear, and return home with no more errors.
Has anyone else the same problem? Please advise.
whitetiger
Nov 20, 2011
3,070
1,515
Kansas City, KS
Hi,
Check the wiring and switches located on the shifter cover. They are on the RH side of the transmission.
kevinkubota
B2550 zd1211 zd1011 zd331 zd326 bx23 zkx49 u35 l3301 l3901 M6060 RTV 900 rt1100
Jan 30, 2024
Richfield PA
Hello, what was the actual problem, I am having the same issue on my m5-111,i replaced the switch and still exact same problem, when i go in 6th gear hi range it sets error code 21 an cuts the rpm back for all the gears
rp3687
M5 111 m7040 DmC rake
Jan 11, 2025
Anyone solve this? Happened to me today in 6th HI. Throttled down all other Hi gears until I restarted and it went away
Assuming it has to do with speed limiter system?
