My M4700 only has 480hrs. but it has spent all of its 15 or so years out in the Missouri weather. It developed a jumpy hydraulic system so I figured water in the hydraulic filters. When we removed the two filters, on top of the fluid being milky, there were pieces of the brake friction disk directly behind the filters. Now I know why only the right rear wheel brake would engage.
What parts do I need to order to repaair the brakes? Just the friction disks, the Plates or the Brake Cam Plate's. Apart from pulling the drain plug, is there a proper way to rid the hydraulic system of the majority of the bad milky fluid?
Thank you.
Thank you.
