M130X Engine Warning Indicator
ElHiggoo
M130X
Aug 23, 2020
Ireland
Hi all,
Unusual problem here, Engine Warning Indicator in my 2011 Kubota M130X comes on between 5-10 minutes of use, sometimes turns off again and comes back on for the remainder of the time it's running, turning the tractor off and on again will reset it, no error codes are thrown on the screen or when I check the diagnostics. Was baling with it two weeks ago and it randomly died in the field, but restarted without any problem and has ran fine since, but the light continues to come on. Sent it off to the dealer for a service and they couldn't find any issue outside of having to replace the turbo. I'm leaning towards some hydraulic issue, as when the light first comes on, it seems to go off if I'm using the loader for a while, eventually coming back on though. Any help would be great, thanks
