M105S third function valve
W3grant
Ipswich mass
I got a 3rd function valve threw my local dealer and the direction are not very good. I need to find out where to take hydraulic pressure from to supply the valve. Any and all info would be awesome! Thanks in advance!
whitetiger
Nov 20, 2011
3,252
1,675
Kansas City, KS
What is the 3rd function valve kit number?
Typically, the hose supplying oil to the loader valve is moved to the third function IN port and the 3rd function OUT port goes back to supply the loader valve.
You in effect are running oil from the tractor, through the 3rd function, then to the loader valve.
whitetiger
Nov 20, 2011
3,252
1,675
Kansas City, KS
The kit number is M9238.
The M9238 kit is not a "Third Function Kit" it is a "Splitter Valve".
It splits the bucket Dump and Rollback to operate a separate function.
If you move your joystick side to side, you will control your bucket.
If you push the splitter button and move your joystick side to side, you will open and close your grapple.
Below are the hydraulic connection instructions. I could not load the entire M9239 instructions as they are too big of a file for this site.
whitetiger
Nov 20, 2011
3,252
1,675
Kansas City, KS
I got it from the dealer portal on Kubota Link
instruction Manual for M9239 Hay Bale Grapple for Kubota Loader LA1301S-1, LA1601S
Document ID MA3508
Status Published Published Date 12/19/2019
If you PM me your email, I can email the entire document of setup instructions
