LX Series Replaces B2650 and B3350
SDT
multiple and various
Apr 15, 2018
3,307
1,099
SE, IN
As expected, the new LX3310 is common rail injected. This should eliminate the regeneration issues that so plagued the B3350.
Cab models have LED work lights and optional air ride seat.
Both models offer single lever FEL hydraulic connections.
Quick connect front hitch similar to BX models available.
Though unclear from my information, it appears that a rear hydraulic outlet is included.
R14 tires available.
HP remains same.
SDT
FUSE
B3350-B2650-Z125s-KX008-Bobcat MT100-Case/Davis TF310
May 24, 2017
77
10
North Dakota
Interesting.....wasn't expecting a full blown replacement for the 50 series but I guess it makes more sense to call the 50 series an LX.....
I really hope they did their homework on that single point, seems the bx80 series ones are prone to leaking as the hours add up on the loader.
So the air ride is an option vs standard now?
That front hitch quick connect system is slick, we had it for our blower and blade with our 2680 and our x1100c uses a similar setup.
Nice to see the rear outlet is now standard
Excited to see the new lineup. Its been great so far, but first sign of weakness out of our 3350 its getting traded off for that 3310.
SDT
Apr 15, 2018
3,307
1,099
SE, IN
I've been told by two sources that an air ride seat will be optional. I do not believe that it is available on the 2650 or 3350, let alone standard equipment.
The preliminary brochure that I have makes no mention of air ride seat but does state that the "deluxe suspension seat" (spring suspension) has been redesigned and improved.
Also the LA535 FEL is mechanically self-leveling, swift-tach, and includes self deploying stands.
SDT
FUSE
May 24, 2017
77
10
North Dakota
HA! I had to go look at our 50 series and yes they both are a suspension style seat....so smooth I thought I was air ride!
Just watched messicks video on the new product releases, the lx cab version looks like basically the same tractor as the 50 series just the changes you mentioned with the biggest one being a different larger engine.
I'm really digging that new mini skid loader!
dlundblad
G5200, L2501, ZD1211
May 16, 2009
503
11
IN
Im not finding any links to this tractor. Just curious what it looks like and such.
Eliminating the larger B models makes sense IMO. Going by Kubota 01/50 logic, the 2601 should be a base model of the 2650. Instead its 3/4 the size. Very misleading at first.
Raymo853
LX2610SU
Jun 26, 2019
71
23
Dorset, VA
Just watched the Messick's video on the show highights and the LX. Makes me wonder if there may be deals possible on the B2650.
SDT
Apr 15, 2018
3,307
1,099
SE, IN
I would not expect any out of the ordinary deals on 2650s. Folks will be looking for left overs to avoid the price increase of the 2610.
SDT
Jchonline
599
Red Feather Lakes, CO
LX series is nearly identical to the B50 series except for the 33 which has a taller hood to accommodate proper sized emissions equipment. All in all the 33 is now a top contender for my next machine at altitude once I get everything on property cleaned up with the M62!
foxnbirchfarm
B2650 w/ Loader, RCR1245 brush mower
Feb 13, 2020
Connecticut
I know some people have seen the product literature, but I found the info on Kubota's website today. Can't post the full link, but go to the main website and add this to the url: /products/tractors/compact/lx-series
I JUST bought a B2650, and the one feature I liked on the new B01 series is the self-leveling loader option. We use the forks a lot and that would be really handy!
Myb3350
B3350 JD430 Moline BG and BF
Jul 4, 2016
85
meridian ms
Hey will be be possible to put the new fuel system on the old B3350 engine if it is the same basic engine 1.5
SDT
Apr 15, 2018
3,307
1,099
SE, IN
Many things are possible if one has enough money and/or time but some things are not practical. This is one such thing.
It would be more cost effective to exchange tractors.
SDT
PA452
B2650
55
Western PA
SDT
+1
Kind of reminds me of the guys on the truck forums who have a 2WD and want to change their truck to a 4WD. Possible? I suppose maybe. Practical? Not really.
powersrp
B3350
Apr 2, 2017
94
Indian River MI
This is new information to me, i wonder if it will have a turbo? listed hp is 31, I love my 3350, 630 hrs and never a hick up. Two years ago i built a rock retaining wall to surround a group of bich trees, im sure some of these rocks were at least 800 lbs and the lil beast drug them out of the swamp and uphill a couple hundred yars on wet grass/slime. One rock i struggled with, i actually hooked the jeep winch to it and all it did was drag the jeep, so back to tractor and strap and gotter done. I think if i ever have emission problems i will look into deleting or drilling holes. Its paid for and im not buying another one. stay safe, stay home. or else——[emoji1784][emoji40][emoji855][emoji1785]
SDT
Apr 15, 2018
3,307
1,099
SE, IN
The 3310 is turbocharged, the 2610 is not.
HP is unchanged vis a vis 2650 and 3350.
SDT
