LX 2610 elec acc on rear of machine
Klutgring
LX2610
Mar 2, 2024
So. Indiana
Hello everyone,
Was wondering if anyone has added a elec acc on the rear of their LX2610??
I have a 12v seeder broadcaster I use for seeding and fertilizering.
Opinion of it would be best to run a 12 ga. Wire to the batt or is their a wire already in place somewhere??
And it is a cab model. TIA
Showmedata
LX3310
May 18, 2022
207
188
Boulder CO
on my lx3310 there is an accessory circuit there but I've found it useless. I tried to use it to power my snowblower chute rotator and it continually blew the fuse so I ran a new dedicated circuit. If your seeder needs more than a couple amps I suggest you give it a home run.
Donystoy
Dec 10, 2013
670
304
Binbrook, Ontario
On my cab lx2610 I installed a three way switch on the accessory circuit with one side for my rear camera and the other side for the oil cooler fan when the backhoe is mounted. It has a 15 amp fuse in the circuit. Reason for oil cooler is that I converted my bh77 to self contained hydraulics.
Chad D.
255
131
Eugene
You’re limited to a 120W load on the OEM circuit back there, so I’d be leery of anything north of 7-8 amps.
If that circuit is like the one on my B2650, it is turned on with the headlight switch, I think. I’d need to dig in to confirm, but I’m pretty sure that’s the way it was. My auxiliary lighting is too much for the OEM circuit, so I just use it to trigger a relay that feeds power from the battery.
Mark_BX25D
Bx25D
Jul 19, 2020
1,799
1,312
That depends on just two things:
  1. How much current does your accessory need?
  2. How long does the wire need to be?
Don't just guess at a wire size. There are tables and calculators online that will tell you what gauge wire you need for a given distance and current.
And please, please, please, put a fuse inline near the battery!
