i discovered water was getting in my fuel storege barrels today with in 2 mints of my discovery my Kubota started running rough i shut it down and looked it over checked oil coolant fuel level i tryed to start it ands she brow a lot of white smoke and ran it 200 rpms i shut i down and checked oil coolant ext agan it was all mint i drained my found a lot of water out of the 10 gallons of fuel i drained out probably a half galon of it was water i when and got fresh fuel and cleaned my sediment bowl and refilled the tank with clean fuel i tried to start the tractor it just smoked did not start just smoked when i cranked it over.
should i drain and bleed my fuel injectors next or is there some thing elts i should try first?
