Looking for info on kubota rtv snow plow
moday
What is a good website for kubota rtv? I bought a used rtv 500 with a Kubota brand plow. 60 inch and 24 inch tall snow plow. I’m trying to figure out how to remove and seller has no info and not finding much on web. Any suggestions? Thanks!
Tim Horton
291
67
Lake Superior
On our RTV 400 the front blade is easy to take off and put on.
Lower the blade on a flat surface until the chain is slack.
Remove the 20mm long pin that runs across under the lower edge of the bumper bracket.
Unscrew the large bolt with the bar across the top. This is a clamp that holds the blade bracket to the flat plate on the front of the mounting bracket. Lift the top lip of the blade bracket up and away from the top edge of the bumper bracket. Back away from the blade.
Unhook the wire harness.
Different years and models may be a little different.
