Hi folks.
I've been in the market for a compact tractor with a mid-mount mower that can do double duty with the snow in the winter, for not much money. I haven't decided how to tackel the snow removal yet. Possibilities include plow, snowthrower or FEL. I may want to put a small FEL on it at some point to do snow and some material moving (mulch, manure), maybe like original B1630 if I can find one, or a Woods LS72. Found something that seemed interesting, so went to look at it...
Tractor is a B7200HST-D, vintage 1984 4WD 17HP hydro trans, with mid-mount mower deck. See pics. Hour meter says 448, and owner not sure if meter works. Based on vintage and condition of tractor, I would guess meter is not working, so hours?
Tractor is not pretty cosmetically (which doesn't bother me); lights don't work, glow plug light doesn't work (but plugs do). Seat is pretty much toast. Deck blades look pretty rough (stone hits, etc.) It's also got a few dings and rust.
Battery keeps steady 12.4V. No blue or white smoke on start-up or otherwise. No apparent issues at startup. Some black smoke under load (but not at idle). Coolant was green & full. Engine oil was black, no milky or watery residue, no rust or off-color. Mid-PTO/deck and 3pt/rear PTO work. Not much play in front wheel bushings and steering seems pretty tight. 4X4, dif lock, brakes, Hi/Lo, For/Rev seem to be in working order (at least as much as I can tell from an uphill ride on wet grass).
Two things worry me about the tractor;
1) I found what appears to be old oil residue below the head/block mating surface. It does not appear to be recent. Not sure if it is oil; if it came from a spill while filling during an oil change or a bad/blown gasket or crack.
2) while everything seemed smooth with the transmission (shifting in/out of hi and lo, PTO on/off, etc), engaging the clutch pedal FULLY produces a noise I can only describe as "clanging", when pedal reaches about 75% of travel, that seems to go away at full depression. Not sure what this means?
What do you think would be a fair price to offer? Is it even worth considering, or am I getting into some expensive repair in the near future?
The owner seems agreeable to me taking it to a professional / dealer to have the tractor evaluated. What should I tell the dealer to look for? Keep in mind that I don't want to get too far into it, if I am not going to buy it.
Thanks for reading my first post, if you've read through this far.
Eric.
Eric.
