Loader mounted snow plow
jdmcb
L6060
Aug 12, 2019
17
Burlington
Ok guys, I need expert advice. I have a western pro plow that I would like to convert to use on the loader of my L6060. I have dual remotes in the back and need to know how to properly set this up. I plan on using a Titan 3 point hitch adaptor plate and I want to add a crossover relief valve.
What crossover relief valve should I use and how do I "plumb it".??
What size hydraulic lines should I run from the remotes on the back of the tractor.??Any suggestions are appreciated.
Thanks
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,448
1,664
Near Lancaster, PA, USA
It would be worthwhile to check some of the threads below for some comments from some who have done similar things. Line size isn't much of an issue on mine. It's plumbed into the small factory 3rd function hoses on the FEL and it's pretty fast even with a restrictor orfice in the line. The fluid requirements of the angling cylinders aren't anywhere near what would be required to run an implement.
https://www.orangetractortalks.com/forums/showthread.php?t=30688
https://www.youtube.com/watch?v=zk_091GVnAo
https://www.tractorbynet.com/forums/snow-removal/403739-ssqa-front-blade.html
https://www.tractorbynet.com/forums/build-yourself/401291-snow-plow-build-finished-underslung.html
https://www.tractorbynet.com/forums/build-yourself/408923-setback-underslung-ssqa-snow-plow.html
