light switch
ttfo
53
Custer, SD
I have a b7100hst-d. when I purchased it, it had a toggle switch for the lights. I am in the processes of rebuilding it. I purchased the stock light switch from kubota and was expecting to find connection screws on the back. There are no connection screws. It does have copper "ports". I am "assuming" i need some kind of special connector, but cannot find anything in the parts diagram. Can anyone help me with what I am missing?
Thanks
kubotasam
Apr 26, 2010
1,209
132
Alfred Maine
The wires get soldered to the back of the switch.
bxray
Bx25d
Dec 1, 2014
712
Cleveland, ohio
You will want to solder in a pigtail wire and put crimps on that so you have a disconnect and an easer way to solder.
May want to tin the wire and contacts first.
Ray
3,091
This is one of my next priorities- I have some LED flasher rear lights (red to rear, amber to the front) to install and when I pulled the switch to check the wiring setup, I found the same switch with soldered-in wires, but the "hot" wire was frayed down to about two strands. I'll solder in a new pigtail, add a connector, & work from there.
