Lift will not go down
mtduvic
L1801
Aug 31, 2019
Denham Springs, LA
I have a L1801 Kubota tractor the the lift will not go down. I have a grader box attached. It is at the top of it's travel. It's seems to bog a little when you try and lift it up futher. Any suggestions on what to check?
TIA
twomany
B7200
Jul 10, 2017
793
138
Vermont
The bore of the lift cylinder on my B7200 got a bit rusty. (not enough splash from the differential I guess)
The piston jambed when asked to go full up. It took my 20 ton hydraulic press to push the piston back out. A few passes with a three stone hone brought the cylinder back to serviceable condition. A good slather of grease went on both cylinder walls and piston skirt on assembly. The entire job took less than two hours once I made up my mind to pull the rock shaft unit.
A test is: can you move the lift arms up more? (Yes I know the box blade is heavy, take it off!)
bikerdib
L4701 with FEL, BH92 backhoe
Oct 5, 2010
210
14
Wallis, Texas
Not familiar with your model tractor but most Kubotas have a speed control knob that regulates the speed the 3 point will lower. On most, it is located below the seat, between your feet. It will close all the way basically locking the 3 point from lowering.
SidecarFlip
Banned
561
When I was younger I had that issue a lot. Now, it's usually down.....:D
