Lift arms won’t stay up.
bcouch
Kabota B7100 HST
Apr 22, 2023
Richmond MO
I have an old B7100 HST. The lift arms raise and lower as they should but they slowly drop while in the up position.
Any tips on what could be causing this?
cthomas
LX2610 HSDC
Jan 1, 2017
843
557
La Farge Wi
Gravity?
It is probably a slight seepage within the 3 point lift cylinder. The old Pasquali tractor does this and I just be careful and live with it.
4,850
If the B7100 has a lowering speed valve close it fully and see if that stops or slows the drift.
bcouch
Kabota B7100 HST
Apr 22, 2023
Richmond MO
Gravity?
I think you’re right. I’ve watched a few YouTube videos and I’m going to replace the lift cylinder seal if I can find the right parts.
Thanks for the help.
4,850
It could just as well be the position control valve. Before throwing parts at it I would suggest you try shutting off the lowering speed valve to see what effect that has.
