Lift arms too short
Kbtaman65
M5040
May 20, 2022
26
10
Marion NC
I have a M5040. I also have an old Ford 2 bit turn plow that I used with a Ford. The plow won't fit my Kubota because the lift arms are too short. The front of the plow hits the
mendonsy
B7500HST/LA302
May 28, 2012
363
38
Mendon, NY
It seems like they should work OK. You would have to use the CAT3 version of the quick hitch to match your tractor and add bushings to the CAT2 equipment.
Mine are CAT1 and CAT2 so they are slightly different. I found some large flat washers that fit over the CAT1 hitch pins and used lynch pins to hold the bushings and washers in place.
