Leveling a Land Pride Quick Hitch / Proper Angle for Brush Hog
DawgHouse
Kubota L3302
May 2, 2025
Good Hope , GA
Two part question…..
1) my quick hitch seems to be tilted (not level right to left) but the lower arms of my 3PH are adjusted exactly the same….can anyone tell me how to evaluate and fix?
2) what is the proper front to back level on a brush hog? It changes depending on how high I am cutting but I was wondering what is the proper adjustment and at what height?
Thanks!
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,535
1,998
Western MT
1. The lower adjustment arm is only adjustable on one side.
2.
SDT
multiple and various
Apr 15, 2018
3,296
1,090
SE, IN
Thanks!
Bush hog type cutters should be level side-to-side and 1/2" to 1" higher in the rear than in the front.
Mowing height should be adjusted to preference and conditions.
animals45
L3301l
Apr 22, 2021
282
Mabie CA
Look at this drawings , you should familiarize yer self with these tractor parts . Theres a rignt & left lift arm , the right is usually adjustable . The pin's of each upper & lower on each side should be the same length .
If not adjust then so they are .
Post 1 in attached link
animal12
DawgHouse
Kubota L3302
May 2, 2025
Good Hope , GA
I can’t the right lifting rod to turn to adjust the level right to left. Does this need to be in the up or down position and can I adjust with an implement on there?
1,816
@DawgHouse
I am not 100% sure I completely understand the question so may not be answering it correctly.
Yes the right hand link is used to level (or tilt) implements. The tractor must be on level ground (rear tires level side to side). The rear tires should be at the same pressure also to make the tractor level.
The implement can be attached and then leveled, but you will probably need to have the implement sitting down on the ground to take the tension off the arms, then turn the right side to adjust. If the right side is greased well you can probably move the implement when lifted, but you may have to use a longer lever over whatever you use to turn that.
AND there is a locknut on the right side that must be loose to adjust and then tightened when it is correctly adjusted.
To make it somewhat easier, I try to get the arms level before I attach the implement and then fine tune the level after the implement is attached. To tilt an implement you can adjust the arms before you attach the implement or block the implement to the angle needed.
Drop the three point hitch to the bottom of its travel before you try to install the implement. Then back up to the implement (focus on the nearest to tractor side of the implement first) and get aligned to the implement pin. Lift and attach that side arm and get it locked on, then try to move the implement or tractor to align the other pin. You can CAREFULLY use the tractor to make the adjustment if you are sure you can move it small incremental distances (parts of an inch, not parts of feet)
If you can’t get the right arm to turn, make sure the locknut is loose and moved back far enough to adjust the position. If it is rusted and gunked up, then you should remove it and clean it up and get it moving again and grease it. There are probably pins inside of it to prevent it from unscrewing completely (keep your feet out from under a raised implement when adjusting it though). If you get it moving and then it gets stuck at its longer length then just assume that it has the pins and don’t try to force it out longer.
jimh406
Jan 29, 2021
2,535
1,998
Western MT
Do yourself a favor and watch the video I posted the link to. It explains how to set one up from the perspective of a manufacturer.
