leaking Transmission fluid
willow
kubota 245dt 4wd slasher ,backblade,ripper
Feb 9, 2012
Canberra Australia
Hi I have a 245dt and when the transmission oil gets hot it comes out of the bottom of the gear lever does this mean I have to much fluid in it or is there some sort of seal missing ,have tried making my own seals but because the movement of the gear lever causes everthing to move around and not seal.
Any bright ideas ,or has anyone else had this problem?It does not come out of pto lever so mayby I should take it off and see what is sealing it.
Willow
