steve
B7100HST, B5001DT/B5100DT, JD-111H, Chevy K2500 DuraMax, CJ-5, CJ-7, TJ jeeps
Vic
After cleaning years of mud and hay chaf off the back of my B5001 I discovered a leak at the PTO shaft. I'm looking at replacing the seal and bearings but not sure of the part numbers. The shaft has a little movement but thought while I'm in there to replace them. The seal 09500-28408 looks to be a good number as it is the same in both my B5001 and B5100 parts manuels. The bearings are an other story. Part of the page with the parts numbers for the B5001 is missing so here is what I've got. Bearings are 08711-30204 and 09711-30205. Are these the correct numbers? Is there a gasket for the cover or does it use "blue goo" to seal it? Thanks for the help!
Steve
Steve
