I have a newly acquired B7100HST-D, and they return fitting for the FEL hydraulics on top of the transmission is loose, and leaks. By loose, I mean it turns with no effort when grab the return line.
The cap also leaks, and I have a new O ring on the way for it. There wasn’t a O ring on the parts diagram for the threaded part of the return fitting, and I can’t seam to locate a owners, or WSM for the FEL.
I have come hear for some wisdom before I dive into this project. Should I remove the return fitting, and add some thread sealant, such as teflon tape, or teflon paste to the threads? Is there a proper orientation for the threaded return that the return hose threads into? Currently it’s at 3 o’clock, as you’re sitting on the seat of the tractor, and that orientation makes the most sense to me.
Is there a place to find a owners manual/WSM for the 1630C on line? I found the parts book on Kubotabooks, but unfortunately they don’t have the others available for the 1630C.
Thanks for your time!
