ken erickson
I apologize if this has been covered before in this forum. I did do a search and was not successful.
I have a later model B7100hst four wheel drive and today purchased a used B2650 snowblower that came off of a B7500. I received the snowblower, the front hitch that bolts to the front of the frame, with the arms that extend to about mid-point. I am missing brackets that attach the arms to the area were the MMM brackets bolt to. I do have the complete pto driveshaft which appears the correct length. I did not receive the control and the two hydraulic lines that run from the tractor high pressure line to the control valve.
I would really appreciate it if someone could take pictures of the sub-frame to tractor frame brackets, and also the control valve and the control valve mounting bracket. Or if someone can point me in a direction for the proper mounting kit manual?
Thanks in advance!
Ken
Thanks in advance!
Ken
