Land Pride disc question
drumminj
L4701, Mule 4010
Nov 4, 2021
156
119
TN
Bought a DH1572 recently and have an odd issue using it with my L4701. I don't have a quick hitch, and the three point lift arms/stabilizers just BARELY fit around the pins to connect up the disc. With the pins pulled out of the telescoping stabilizers to give them full range of movement, I have maybe 1/4" of clearance around the width of the disc to mount it.
So basically I have to line up perfectly to mount it, and unmounting is basically impossible as I have to set it down on ground with the lift arms perfectly centered to be able to get them both to release.
Am I missing something? Any tips/suggestions aside from buy a quick hitch?
SDT
multiple and various
Apr 15, 2018
3,388
1,164
SE, IN
Not familiar with your model disc. Is it possible to reverse the pins such that they point inward?
Alternatively, if the disc is quick hitch compatible, the pins on the disc should be removeable. IF so, it might be possible to replace the removeable pins with conventional pins directed inward.
bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
Apr 3, 2014
321
27
23
Mobile, AL
Can you switch the pins to point in instead of out?
Flintknapper
L2350DT
May 3, 2022
2,013
2,552
Deep East Texas
Common problem with 'some' Cat 1 implements. Just 'flip' the pins inward as already suggested above.
drumminj
L4701, Mule 4010
Nov 4, 2021
156
119
TN
Interesting..would have never thought of that! I will give it a try.
Thanks everyone for the feedback
