LA525 Loader 66" bucket weight
LMTractorGuy
L2501HST, LA525, RCR1260, BB1260, Titan 48" SS Forks, Stump Bucket
Sep 20, 2016
70
SC
Does anyone know the weight of the kubota 66" QA bucket on an LA525 Loader. I am only curious because I have ordered the Titan 48" SSQA forks and the total weight is listed as 326 lbs. I want to know the bucket weight so I can calculate how much can be safely picked up with the forks and not exceed the LA525 Loader rating.
Kennyd4110
Vendor Member
Sep 7, 2013
1,431
763
Westminster, MD
www.boltonhooks.com
I don't know the answer to your question, you don't need to calculate anything, if the load is to heavy to pick up-then it simply won't, thats the built in protection the PRV (pressure relief valve) offers. Make sure you have adequate REAR ballast and go to work...
LMTractorGuy
Sep 20, 2016
70
SC
Pat. Thanks for the information. Where did you find that data?
Sammy3700
L3800HST,524Loader,BH77,Landplane,Disk,Mowers and more
Feb 20, 2012
459
61
Red Springs, NC
I am assuming you have a L tractor, you might want to check your hydraulic pressure if it does not lift what you think it should. I have bumped up several to 2300-2400 psi, the ones I worked on came around 1900 from the factory. I have been told they send them out like this because not every one wants a loader.
