LA525 cylinders not extended same length
Poohbear
Jul 6, 2018
529
195
Gilmer,Tx,United States
I got my fel in a bind today with my pallet forks on. I think one fork pushed that sides hyd cylinder in putting it shorter by about 1 1/2 in. Is this possible or did I bend the rod. There is no binding , noise , etc extending/reversing .
How do I make sure no pressure in lines so I can remove the hoses & move the ram to line up with other side or have I bent something expenseive. I'll have time tomorrow to do some actual trouble shooting.
SAR Tracker
Nov 17, 2020
246
364
Central Oregon
Turn off engine, cycle joystick in all directions several times, with FEL on the ground. That will relieve the pressure.
whitetiger
Nov 20, 2011
3,277
1,689
Kansas City, KS
You have twisted the indexing bar between the two plates for your quick attach.
Set your attachment off, extend the cylinders a few inches, and put a block of wood in behind the pad and loader on the short side. Now move the joystick as if you were curling the bucket back. When the long side becomes equal to the short side, curl a little more. Move the lever to dump to release the pressure from the wood block and lay a straight edge across the quick attach pads and see how closely you have them aligned. A little tweaking at a time and you will get them back in alinement.
Poohbear
Jul 6, 2018
529
195
Thanks . I was backing up with a load of limbs I had stacked & caught the right side on a tree so twisting makes sense.
I'm very inexperienced on hydraulic stuff but I need to learn more cause I could tear up a ball peen hammer
Poohbear
Jul 6, 2018
529
195
Thanks Whitetiger, the block worked so easy.
It dawned on me after putting my bucket back on that this uneven extension of the curl cylinders must have started awhile back as it seems it was getting more difficult to hook up each attachment change. Works like it is supposed to now
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
whitetiger
Nov 20, 2011
3,277
1,689
Kansas City, KS
I have straightened more of them than I can count. A few minutes, a block of wood, and a straight edge, the problem is solved.
